Farmall F-12
Bill Copeland
09-10-2007 09:08:44
Can anybody give me the correct length of the fuel pump pushrod? If the cam is badly worn how do you check for correct length? Also would like directions on how to set the float level for the carburator
Andy Motteberg
09-10-2007 20:04:31
 Re: Farmall F-12 in reply to Bill Copeland, 09-10-2007 09:08:44
I've heard that the push rod should be exactly 7 inches.
Doug N
09-10-2007 15:03:51
Bill, I don't know about length. I don't have it in front of me at the moment. But I can give you the fuel pump lobe measurement. The lobe is round so it will measure the same all the way around. It's offset, that's how it pumps. Anyway it should measure somewhere in the neiborhood of 1.502". Hope this helps. Doug N
Fawteen
09-10-2007 12:43:23
I don't have any data on the fuel pump drive rod length, but I don't think it's particularly critical. As long as you're getting enough stroke to move fuel, you should be okay.
On the carb float, the book says to adjust the float so the fuel level is between 22/32 and 25/32 below the bottom edge of the top cover of the carb.
