Not Exactly
Andy Martin
09-12-2007 12:57:40
Not exactly, what is true is that volts divided by ohms will give you amps. If you double the voltage you also double the amperage, that is why 12v will burn out a 6v bulb.
An incandescent bulb does not have fixed wattage, only fixed resistance. A 30w bulb will draw 5 amps at 6v, but that will rise proportionally with voltage.
