power steering on LPG M
bnowen
09-18-2007 17:53:25
I would love to put PS on my M, I have noticed, though, that where the charlynn unit usually fits is where my Propane tank sits. I don't think there is room in front of the tank and still clear the hood. How is this usually done, if it is done? The tank is turned horizonal with the steering shaft passing through the tank. This was obviously added on since the tractor is a regular M. Any suggestions?
Bob Kerr
09-19-2007 07:16:30
 Re: power steering on LPG M in reply to bnowen, 09-18-2007 17:53:25
My M has the Belen PS on it, and I don"t think that style would work out at all on LP. The motor unit mounts right in front of the steering wheel and over the tank on my gas M. I am going by a LP H I looked at a while back. I am not familliar with the Charlyn type.
)wen Aaland
09-19-2007 02:51:33
The charlynn unit fits in front of the plate that holds the oil pressure and temp gauge. If your tank is like the one I have, the tank is all behind that plate, so there so not be any interference putting the PS unit on.
Lee in Iowa
09-18-2007 22:13:45
Hope I don't sound like a smarta$$, but you could change it back to that high priced gas and use the regular charlyn PS unit and have lots of power if they put the high compression stuff in the engine.Lee
