Missing s.n.
Bobby the oneab
02-17-2000 17:22:57
need help identify IH M TRACTOR SN#PLATE IS MISSING NUMBER ON MOTOR UNDER FIREING ORDER NUMBER 1.12.L
NUMBER ON FRAME IN FRONT OF BREAK PEDAL 8002-DD
ALSO 12.23K AND ON BELT PULLEY 8709-DD
WOULD APPREATE ANY HELP THANK YOU
Skip
02-18-2000 06:43:53
 Re: missing s.n. in reply to Bobby the oneabee tractor manc., 02-17-2000 17:22:57
According to Guy Fay's data book the eng. # should be on the right side of block above the crankcase breather, This should be close to serial # of chassis.
Jim Becker
02-17-2000 18:52:09
1 12 L = Jan 12, 1942
12 23 K = Dec 23 1941.
You have a '42 model.
Simp
02-17-2000 17:53:33
The only number that I can tell you a date on is the one on the block under the firing order. The L on the end of the number is the code for the year 1942. I am not sure about the rest of the numbers. There should be more numbers like the one on the block in places such as both rear axles, rear hubs, front end, and a few other places. If you can locate these and post these numbers, we can probably tell for sure what model it is.
