LOADER
brett steeves
09-27-2007 16:28:17
HOW MUCH FABRICATION WOULD IT TAKE TO PUT A LOADER FOR A H ON A SUPER C
Janicholson
09-28-2007 17:39:22
 Re: LOADER in reply to brett steeves, 09-27-2007 16:28:17
Andrew is correct, the H loader will be heavy and long and wide ETC. The work is more than the result. In addition the H loader will be able to overload the C (I believe the best intentions are often derailed by the need to lift heavy things) SCs can be broken in half easily. (I've seen three one with a loadre, and two from hitting frozen ruts with the front wheels. Snapped the engine block at the front bolster mounts on two, and the torque tube on the loader tractor. JimN
Andrew Z
09-27-2007 17:28:14
It would be prob. to heavy for that to work right. Try and find a loader for a Super C. I have a Super C with a loader and H with a loader and the super c weighs maybe 400 - 500 with a blade i have on it, the H loader that i have is close to 1000. The Super C with no frame rails will stress it out alot with that much weight on it. Not sure what type of loader you have but i would play it safe and not break a good Super C.
Good Luck
Andrew
