Remembered something else!
Bob Kerr
10-10-2007 08:26:13
Come to think of it I did have the float hang up on mine because of a drip of sealer that was on the edge of the float opposite of the arm. It was catching the side of the float bowl I took a fine file and dressed up the drip and it stopped that. The sealer that is on Rices floats is compatable with alcohol. The old floats aren"t and will sink if alcohol is in the gas. HERE is something I did just remember about. I did notice on the inside of the bowl there is a machined grove going around the inside.After trial and error several times, I set my float to that line and it worked perfectly! I think the line was put there to help with assembly when it was new. I have seen the line cut in many of those carbs.
