connecting rod question
brian comer
10-11-2007 11:42:33
I need to know how the connecting rods in a farmall 300 are installed on the crankshaft. I was told that the stamped numbers on the rod caps face the cam side of the motor. Is this correct or does the rod caps face the cam side since they are offset. I"m not sure please help!!! I need to get my tractor back together. Thanks, Brian
ChrisAS
10-11-2007 13:13:57
 Re: connecting rod question in reply to brian comer, 10-11-2007 11:42:33
stamped numbers face cam.
Janicholson
10-11-2007 11:53:09
The caps are offset to the carb side of the engine. They can be seen at caseih.com search for parts, start your search here. Enter farmall, then select H then crankshaft and associated parts. JimN
