farmall c
bigfutty
10-18-2007 07:39:20
I have a farmall C that I put a engine out of a 140 in and the thermostat housing and the radiator neck do not line up they are about 2 inches off when the radiator is in the proper position. I was wondering if anyone had a idea how to fix the problem. I was wondering if there was another housing that i could use that would work or any other ideas. of course i want it to look like it is suppose to and not look like a hack job.
Janicholson
10-18-2007 09:55:45
 Re: farmall c in reply to bigfutty, 10-18-2007 07:39:20
There may be molded hoses in the radiator hose section of NAPA (or others) that has the offset built in correctly, even though designed for a caddy or somthing. You might need to do some Isle walking to get there. JimN
Andrew Z
10-18-2007 08:02:28
You would have to get a radiator off a Super C, 100, 200, 230, 130 ect too make the exact fit. the 123cid enigne had a larger radiator than the 113cid.
Andrew
georgeky
10-18-2007 08:06:34
 Re: farmall c in reply to Andrew Z, 10-18-2007 08:02:28
Andrew, that won't work. The sheet metal will not fit back on the tractor with a taller radiator. He might try the water neck for the straght C.
Andrew Z
10-18-2007 08:14:49
 Re: farmall c in reply to georgeky, 10-18-2007 08:06:34
I was saying that if he wants to get the right set up, then he would have to get one of them, then yes it would need a SC grill also the fuel tank would need the 1" reiser added. I was just pointing out why it did not work witth the current one
Andrew
Andrew Z
10-18-2007 08:23:05
 Re: farmall c in reply to Andrew Z, 10-18-2007 08:14:49
Sorry for the confusion there guys
Andrew
