radiator question again!?!
Andy Sommer
10-18-2007 08:08:15
I cut the bolts off the bottom of my H, had too. Is it best to brazed new bolts back on OR someone told me to wire weld them on. I would use a oxy/act torch which I am comfortable with, the wire weld I don't think would seal up as easy.... Next question, one of the bolts or part of one fell back into the radiator, oooooppps, don't think it will fit through the large hose port on the bottom, also I will need to either rethread or repair the 3/8' steel drain tube, As always I appreciate all advice
Janicholson
10-18-2007 15:49:55
 Re: radiator question again!?! in reply to Andy Sommer, 10-18-2007 08:08:15
Pull a picture off of the caseih.com site of the radiator, and bolts. Take it to a good radiator shop and find out a estimate they will stick to. If it is more than a replacement, get a new one. JimN
Pat-CT
10-18-2007 14:46:43
at this point i would consder finding a new one if you have the money just less hastle
