Farmall BN
BobOHIO
10-21-2007 15:46:49
My BN has an occasional miss or pop to it. But if it is run in 3rd gear or under a load up a grade it smooths out and sounds real nice. Also, the faster I run the engine the better it sounds. Is this a rich or lean condition with the carb maybe? Thanks
ScottyHOMEy
10-21-2007 17:10:06
 Re: Farmall BN in reply to BobOHIO, 10-21-2007 15:46:49
Sounds like it might be a fuel issue, but I'm also wonderin', mag or coil ignition?
Red Dave
10-21-2007 15:54:10
I have a B that did the same thing for a while. I discovered that there was deterioration of the contacts and carbon tracks on the inside of the distributor cap.
When I replaced the distributor cap, it also fixed that occasional miss that it had.
Don't know what is causing yours to do it, but that is what fixed mine.
BobOHIO
10-21-2007 16:45:23
 Re: Farmall BN in reply to Red Dave, 10-21-2007 15:54:10
Thanks Dave. I'll pull the cap and check it. I sort of ruled out ignition because it runs good and smooth under a load. I thought ignition would pop all the time? I'll take a look at points and cap tomorrow. Thanks again Bob
