Super A Hydro leak
Adam Vaught
10-21-2007 18:24:12
Hey Guys, I seem to have a hydro leak on my super A that I cannot find. I add fluid and after a couple hours the fluid level has dropped significantly. Could the fluid be entering the engine crankcase? Please help!
VAJerry
10-21-2007 19:03:18
 Re: Super A Hydro leak in reply to Adam Vaught, 10-21-2007 18:24:12
Good possibility. Drain your crankcase and see how much you get out. Pump is a simple and cheap rebuild. Unless shafts are worn.
Adam Vaught
10-21-2007 19:06:38
 Re: Super A Hydro leak in reply to VAJerry, 10-21-2007 19:03:18
I did drain oil and it seemed like too much oil came out. How does hydro fluid enter the engine? What type of oil should I run? Thanks
gene bender
10-21-2007 19:58:49
 Re: Super A Hydro leak in reply to Adam Vaught, 10-21-2007 19:06:38
The seal on the pump is bad not hard to fix. You can just add engine oil to the pump till you get it fixed wont hurt anything.
