D466 on 560 flywheel question
6708
10-23-2007 11:04:34
I made up my mind to put a D466 on my 560, I now know that a 966 flywheel will not fit in the bellhousing, I posted several similar questions about the transplant in the past, I have forgotten the name but someone told me that a company makes a flywheel for this application?? any help is greatly appriciated.
Thanks
reborn binder
10-24-2007 19:32:05
 Re: D466 on 560 flywheel question in reply to 6708, 10-23-2007 11:04:34
u probly have a14 inch flywheel but the 12 inch will not work either.the 12inch in a 66 or 86 tractors r the same clutch in a 560.u have to grind out hyd hub out of the center of press plate of 66 or 86.
BradD
10-24-2007 16:51:11
the 560 cluth will bolt to a 966 flywheel they used the same clutch.
K.B.-826
10-23-2007 18:03:21
I'm really surprised that the 966 will not fit. Where is it hitting? Are you positive it's from a 966? Does your 560 clutch pressure plate bolt up to it?.
6780
10-24-2007 11:10:30
 Re: D466 on 560 flywheel question in reply to K.B.-826, 10-23-2007 18:03:21
No it will not bolt up, unless my parts poeple gave me the wrong flywheel.
