Farmall B won't start
BigTex
10-26-2007 14:16:58
I've replaced the battery, solinoid and had the starter checked. All are good. But when I turn the key, nothing. What do I check Next?
BigTex
10-29-2007 07:29:20
 Re: Farmall B won't start in reply to BigTex, 10-26-2007 14:16:58
Thanks, I narrowed it down to the keyed ignition switch this weekend. I think I'll convert it back to just a button switch when I fix it. Where is the best place to get an original or original replacement?
El Toro
10-26-2007 16:38:48
You need to check to see if you have battery voltage at your key switch from the wire going to the solenoid. This should only have voltage when in the cranking position when you twist the key to crank the engine. Hal
PS: You should check at the solenoid too to see if there's voltage when that key switch is in the cranking mode.
gene bender
10-26-2007 16:01:13
Are you sure your started isnt locked to the ring gear.
don g
10-26-2007 15:39:24
definately electrical.get a meter and check voltage from source.somewhere along the line voltage will not show up on meter and u have found your problem.
ScottyHOMEy
10-26-2007 14:48:40
Ummm . . . what key? How are you wired?
Andy Motteberg
10-26-2007 14:55:47
 Re: Farmall B won't start in reply to ScottyHOMEy, 10-26-2007 14:48:40
Some people replaced the old switch with a key switch. My H had that, but I converted it back to the button starter.
Red dave
10-26-2007 16:17:37
 Re: Farmall B won't start in reply to Andy Motteberg, 10-26-2007 14:55:47
A Farmall B didn't come with a solenoid or a "button" starter. Whatever he has, it is completely aftermarket, so he will have to go through it wire by wire and piece by piece to figure out what was changed and how it was done.
I think Gene B's idea is a good place to start, they are known for having that problem from time to time.
Andy Motteberg
10-26-2007 14:42:31
Make sure the key switch is good, you can buy a new one cheap. If that does not do it, you might have bad battery cables or connections.
