Bad three bolt steering spindles
Bob Haiar
10-30-2007 09:40:20
Is there something out there that I can take 5 bolt spindles off of and they would fit on my wide front end of my International M? I have a loader on the tractor and the 3 hole spindle are wore out and the wheel tabs keep breaking off the wheel.
Jim J
10-30-2007 16:24:47
 Re: Bad three bolt steering spindles in reply to Bob Haiar, 10-30-2007 09:40:20
I can get new 6 bolt hubs to fit the M spindles. The inside bearing is an odd size making it hard to swap hubs. The hubs are $88 each
Bob Haiar
10-31-2007 08:57:34
 Re: Bad three bolt steering spindles in reply to Jim J, 10-30-2007 16:24:47
I would like to know your best price for a pair of 6-bolt hubs, bearings, and wheels (15"?) that will fit on the M spindles. Thank you.
Nebraska Cowman
10-30-2007 15:39:13
Some Schwartz wide fronts had 6 bolt hubs. I do not know for sure if they will interchange.
RustyFarmall
10-30-2007 13:13:57
A good welding shop can repair those wobbled out holes in the hub, and then the trick is to make sure that the bolts are TIGHT.
Janicholson
10-30-2007 11:21:04
With experience of both the loop and clamp style wheels/rims, there was no issue unless they got loose and augered out at the holes, or bound threads on clamps. There has been no repeated mention of issues on this site either. New rims and bolts might do it. Hubs from other farmalls can probably be adapted to work if you purchase bearings that are sized for spindle and hub and spread between bearings. JimN
gene bender
10-30-2007 10:39:25
Mite need new rims as we had a loader on a M for yrs and no problems.
