Daniel--SA clutch job.
bronco
02-21-2000 20:33:20
Does the SA have a pilot bearing? And where would you get the flywheel re - ground ?
Daniel
02-22-2000 08:43:38
 Re: Daniel--SA clutch job. in reply to bronco, 02-21-2000 20:33:20
It's accually a bronze bushing press fitted into the end of the crank. The flywheel can be ground by most automotive machine shops that do head work, engine rebuilds ect. Our local IH dealer does it, too. It's best to get someone that can grind not just turn it on the lathe. Good Luck.
