Garden sprayer/luber...
Bob
11-15-2007 21:43:29
Go to WaldoWorld, and get a $10.00 plastic pump-up garden sprayer. Cut the nozzle off of the plastic wand, and clamp a length of 5/16" rubber gas line to the remains of the wand, and the other end to a "barb" screwed into the oil gauge port. Fill it half-full of clean engine oil, and pump it up with the hand-operated air pump. When you press the lever on the wand, the oil galleries will be forced full of oil.
I'm thinking, though, that there's probably a plug left out somewhere inside the engine, that was taken out to clean the oil galleries, and forgotten, and you have a LARGE "internal leak to sump".
Shawn P
11-15-2007 22:19:21
 Re: Garden sprayer/luber... in reply to Bob, 11-15-2007 21:43:29
I don't think a plug could be left out because I didn't do anything in the block. Could it be a clogged line somewhere or would the pressure from pumping the oil in clear that? Thanks, Shawn
