Brakes
Boots2563
11-18-2007 13:00:08
I need some help on adjusting the brakes on a H farmall. I need to know how to do it.I looked at the shoe and it is in good shape but I have no brake on the right side.I also want to know what that set screw is on the bottom of that thing where the brake shoe is.
Thanks David
little john
11-18-2007 14:57:07
 Re: Brakes in reply to Boots2563, 11-18-2007 13:00:08
And make sure the brake band is not soaked with oil? Lots of them are due to a leak past the seal on the shaft into the tranny.
Yugrotcart
11-18-2007 13:38:17
David,
Adjust the turn buckle until you have about 1 in play in the brake pedal. Tighten the bolt on the bottom of the brake cover, then loosen about 1/2 a turn. This bolt keeps the brake band from dragging on the brake drum.
Paul
Wayne in MN
11-18-2007 14:43:45
 Re: Brakes in reply to Yugrotcart, 11-18-2007 13:38:17
After you get the pedal free play to the 1" range, lock the brake pedal in the fully applied position, then adjust the bottom set screw to 1/2 turn out.
