drawbar mount
Boots2563
11-27-2007 11:50:39
Can anyone give me a part # for the swinging draw bar pivot mount on a 39 H farmall and also the draw bar if it has one. I got to have one and the place where I found this stuff has it by the piles he told me.
Thanks David
Owen Aaland
11-28-2007 05:00:00
 Re: drawbar mount in reply to Boots2563, 11-27-2007 11:50:39
If you are trying to be 100 percent authentic you will need to find one that uses a headed pin instead of the later style that uses a cap screw and large washer to hold in a straight pin. I do not know when they changed but my 40 H has the early style and my 43 had the later style. Early style meant that you have to remove the three large bolts to remove the drawbar instead of just one small one.
GA Dave
11-27-2007 21:14:44
 Re: drawbar mount in reply to ryanroth, 11-27-2007 11:50:39
Boots, go to the CaseIH online parts catalog and you can print out exploded diagrams and part numbers. David.
Wayne from MN
11-27-2007 12:07:08
Where are you located?
I have a couple of them.
Boots2563
11-27-2007 12:14:48
 Re: drawbar mount in reply to Wayne from MN, 11-27-2007 12:07:08
Cooper Texas Whitch is about 80 miles east of Dallas Tx.
