Okay, new FA 140 thread, electrical ??
1fortyfanatic
12-02-2007 19:47:56
Well, let's see just how good you guys are. Thanks for the responses to my Farmall 140 post. I put a reply in there, but messed it up.
Okay, approx 1967 Farmall 140 (serial #354XX), and it runs great; but the battery drains overnight. Battery is in horrible shape and I will replace that first; but assuming a drain somewhere, what is the most common cause for a discharging battery on these units when left outside for over ten years? It was used weekly, but still sat out and the switches, starter button, and wires are rusted and weathered. The light switch just doesn't work anymore.
The generator seems to put out plenty of juice as it will run forever once started, and with a jury-rigged switch, the lights are bright while running. The regulator looks like it hasn't been touched in over ten years. Any tips? Thanks.
Dave
glennster
12-03-2007 09:28:25
 Re: Okay, new FA 140 thread, electrical ?? in reply to 1fortyfanatic, 12-02-2007 19:47:56
i just in the process of fixing the 240 i picked up , it had a drain too. turns out the voltage regulator got water in it and rusted up, closing the points in there. new v-reg and good to go. to find your voltage leak, disconnect your ground cable, then clip a test lite to the ground terminal on the battery, either + for pos grnd, or - for neg ground. and then put the other end of the test lite to a good ground on the tractor. if you go a drain with everything off, the lamp will lite. start disconnecting wires until the lite goes off, that will point you to your problem.
1fortyfanatic
12-03-2007 16:35:07
 Re: Okay, new FA 140 thread, electrical ?? in reply to glennster, 12-03-2007 09:28:25
Glennster, Very detailed and eliminating testing proceedure. Will do after new battery. First on my list will be to open up the regulator and see what is going on in there as far as rust / failed contacts. If I have to replace it, I think I'll take Hugh's advise and go new harness with alternator & switches. It's nice that I only have to jump it to start it, but I'd perfer to be able to start it if I'm on the road and accidently kill the engine. Don't like leaving them running. Thanks guys!
Dave
NawlensGator
12-03-2007 07:34:21
Changed the electrical on both my 140's ('68 and '71) as follows:
1) 12 V alternator, neg grnd
2) new wiring
3) electronic ignition
4) flame thrower coil
5) opened spark plug gaps from .025 to .045
No problems since.
1fortyfanatic
12-02-2007 22:51:58
Hugh, thanks. Yes, it is 12 volt, and yes I have an operators manual for it. The manual shows both a generator set up, and an alternator set up. I'd like to keep the unit as stock as possible, but will consider an alternator switch over. What changes would that entail?
Being the paranoid type, I'll replace the battery just for the security of a new one and the warranty for a year or two.
John, how do I assume that there is a drain? Well, it would just be par for the course with my luck. Assume the worst, and be tickled with anything less. I will pull all the nuts on posts, inspect and clean for good ground. I already bought a new pos and neg cable, since the leads were sketchy at best.
I was just curious if there was a fault that folks with more experience than me, have seen over and over with tractors that sat out for years.
Should have seen me driving that thing home 10 miles in the cold. Ignoring the frozen snot, you wouldn't believe the grin on my face all the way back!! Thanks.
dave
Janicholson
12-03-2007 13:04:58
 Re: Okay, new FA 140 thread, electrical ?? in reply to 1fortyfanatic, 12-02-2007 22:51:58
Just after shutting it off, pull off a battery cable and wedge a tail light bulb between the cable and terminal, touching the side to the terminal, and the tip to the cable end. If it lights (even glows), it has a drain. JimN
1fortyfanatic
12-03-2007 16:29:35
 Re: Okay, new FA 140 thread, electrical ?? in reply to Janicholson, 12-03-2007 13:04:58
Excellent basic test. Thanks, I'll do that.
Dave
Hugh MacKay
12-03-2007 03:36:45
Dave: I've had my SA and 130 a long time, in fact I've owned 6 of these tractors since 1958. I tinkered for years trying to keep these tractors original. 15 years ago I needed to operate a 12 volt motor, thus changed my 130 to 12 volt alternator.
Since the 6 volt genertor was still working I set it aside as a spare for my SA. I put a new 6 volt battery in the SA and within two weeks both generators were toast. I took my two generators and off to a rebuilder I go. I told him I have a new 6 volt battery, thus it has to be 6 volt and it has to be quick. He turned to me, said, "Quick with those old generators will be 2 weeks as I don't have the parts on hand, plus it will be 3 times the money of a new 6 volt alternator. Quick with the alternator will be 5 minutes, as all I need do is change the internal regulator."
Those two tractors have basically been 15 years trouble free since. The 130 did require a second alternator however that was caused by a short in the wiring harness. That new 6 volt battery in my SA was there for 13 years. I never got that kind of service from a battery in my life. Back years ago I had as many as 4 of these tractors on the go, and I always had a bushel of points, condensers, rotors, coils, caps, voltage regulators, etc., much of it, I thought too good to throw out. I was constantly tinkering with these tractors trying to keep electrical systems working, all the way from lights, generator, regulator, battery, ign, etc. you name it, trouble was the name of the game.
Personally if I were you I'd completely rewire the tractor, go for new switches and do it for 12 volt alternator, positive ground.
For me gone is that bananna box of used electrical parts that might be good enough in a pinch. I usually go to CaseIH once per year to pick up items like oil filters, few ign parts, etc. just too have on hand. Usually I'm on the road when I find myself having time for that visit, thus my own inventory is from memory. I find myself now, with 3 tractors, 8 new sets of points and condencers, 4 new rotors, 3 new caps and other assorted new items. I had so many years of lugging this stuff home, I can't get out of the lug parts home mode. Just the greatest problem one could have.
Now, if I've talked you into an alternator, John is much better on the wiring than I, although I expect you can got directly to that alternator diagram in your manual. I can help you with the alternator mount, it is very easy to install a GM Delco on a 140. The trick is get it placed so it's within an inch of engine block. Did you notice, I never suggested changing the voltage, nor would I, either way.
1fortyfanatic
12-03-2007 16:25:49
 Re: Okay, new FA 140 thread, electrical ?? in reply to Hugh MacKay, 12-03-2007 03:36:45
Hugh, excellent points and they are well taken. Whether I get the battery to charge or not (assuming it isn't now)will be the deciding factor. If I need to delve deeper, then I think you are right, I might as well go with an alternator. The diagram(s) should help, but if I run into trouble, I'll be back here to tap your brain. Thanks.
Dave
John T
12-02-2007 20:50:50
While there may well be a high resistance short that can drain the battery, I dont see how you can just assume that for sure just yet until you get a good battery in place. That being said, very severe rusted switches or bad cracked wiring insulation is where Id start looking for shorts. Besides, the switches need replaced anyhow and youre gonan have to end up replacing some wiring so Id get that done n then see if there are any shorts. The regulator may well be corroded to the point it will no longer operate properly but again Id try it first.
Once you get the switches fixed and a good battery post back if you need troubleshooting tips in case any of the charging system isnt workign n we will go from there. You need to insure good grounds on the genny and regulator since its set n rusted.
Let us know
John T
1fortyfanatic
12-02-2007 22:55:02
 Re: Okay, new FA 140 thread, electrical ?? in reply to John T, 12-02-2007 20:50:50
See above new reply.
Hugh MacKay
12-02-2007 20:38:09
Dave: Not sure I'd do the battery first, it may look bad but could be fine. Read what I said to NDS on the old thread. I realize your generator may be working, however I'd look alternator, far superior charging system and you will buy a new alternator roughly same price as a regulator for the current generator.
You'll need to replace those switches anyhow, you may as well do it. It could be the battery drain is in the switches or the wiring harness. I'll have to do a bit more detailed reading, but isn't that tractor already 12 volt. I have the IH Blue Ribbon Service manual and serial number 26801 to 45000 shows a 12 volt battery in diagram.
140 started off as 6 volt positive ground and ended in 79 as 12 volt alternator negative ground. There were 3 changes in electrical during 140 production, and this manual contain diagrams for all 4 systems. It changed at 26801, then 45001, then 57723. Only up to 26800 shows 6 volt battery. The other three systems show 12 volt battery.
If you want a diagram send me a fax number or mailing address. If you have the proper operator's manual for your tractor, it should contain a wiring diagram for that specific system.
1fortyfanatic
12-02-2007 22:57:50
 Re: Okay, new FA 140 thread, electrical ?? in reply to Hugh MacKay, 12-02-2007 20:38:09
see above new reply, oops
