H farmall help
Booth2563
12-03-2007 12:29:50
I got a H farmall 1939 modle and that big pump under the gas tank I guess it would be the belt pulley pump started leaking oil. I thought it was a gasket so i pulled the pump off and found out it was not the gasket.I see where it is leaking oil it is comming out the back where it looks like a plug goes or maby a freez plug something like that. I want some one too tell me what it is that goes there. I see a hole in it and turned the pump up to that point and oil came out the hole that is there. I also scraped it with a screwdriver and made another little hole so it is paper thin what ever goes there. Can someone tell me what to do to fix it.
Thanks a lot David
Booth2563
12-03-2007 12:57:37
 Re: H farmall help in reply to Booth2563, 12-03-2007 12:29:50
Thanks Jim that is what i thought it was was a plug. would you know what size I would need.
Thanks David
Janicholson
12-03-2007 13:11:19
 Re: H farmall help in reply to Booth2563, 12-03-2007 12:57:37
The old one comes out using a chisel take it with you, I have no idea the size off hand, ours doesn't leak yet Jimn
Janicholson
12-03-2007 12:43:14
The part you describe is the Belt Pulley right angle gear box. (not a pump) the oil is comming out of a core plug made from mild steel and rusted through. Knock it out and purchase a brass replacement plug from NAPA that has a bolt in its center to swell it up. They are mistakenly called freeze plugs. Welch plugs and core plugs are correct. JimN
Booth2563
12-03-2007 12:41:13
sorry where this leak is there is a hole there with a shaft and gear there. the gear shaft is in that hole.
