Here is the number!
Bob Kerr
12-06-2007 08:37:54
BU-1205 there is no name on the box, but it fit right in. Besure to check the wear pattern inside the input shaft hole. Mine was deep and I had to find a better gear. Replace the gear on the lower shaft it rides on to keep the whine down to a min. Beware of the after market gears, they SCREAM when running for some reason. You could hear mine loud and clear 2 blocks away! I sent them back and found better used ones.
