Farmall 560
billde
12-16-2007 14:09:56
Went to start the 560 gas today and no go. It is 20 deg here but it normally starts in this kind of weather. I have fire at the points, plenty of fuel.?? Will go get a tune up kit, what is the hottest plug I can use for light duty work.
Janicholson
12-16-2007 19:57:46
 Re: Farmall 560 in reply to billde, 12-16-2007 14:09:56
If your plugs are fouled, and pretty new, just go up one heat range. If they need to be changed that may just do it. Check the spark at a plug before replacing parts. Knowing what is wrong is 90 Percent of being a great mechanic. Throwing a tuneup on it might not make a difference, then there would be lost time/money. If there is good spark, and the fuel is getting to the carb, it may not be getting beyond. I would pull a spark plug wire off and put a good plug on it and against the block. If it sparks when starting, I would then put a squirt of gasoline in two or 3 cylinders with a squirt oil can (just one squirt each) then put the plugs back in and try it. If it fires then dies, you know it is fuel not spark. JimN
