IH manual GSS-1024-Touch control handbook?-help
big red 1
12-18-2007 08:46:55
I recently purchased this.The Diagram of the block shows a touch control block with a solid top.This is good as this is what I have.However it doesnt show Ih part# in the description- I need to replace #16 check valve actuator.When I order the part thru IH 353953R1-it is to way to thick to fit it the bushing and not as long as the one that broke-I dropped it-.Plus all IH diagrams I see on line have the removable top perhaps a sign ?Any ideas what might be going on.I wonder if there is an old part # I should be looking for.It would appear that the solid top is an early model?
Any ideas to help locate part or a prt # would be appreciated
Thanks
Randy
Randy in NE
12-18-2007 09:02:08
 Re: IH manual GSS-1024-Touch control handbook?-help in reply to big red 1, 12-18-2007 08:46:55
I just looked in the parts manual for my C. There are different part numbers for different serial numbers. If you drop me an email with the model of tractor that you are working on I can send you the parts diagram and the corresponding part list. Randy
