Hi, I'm still working on this old industrial tractor with backhoe with its various problems.I have previously noted that the carb throat above the bowl and below the intake manifold used to sweat. Now this winter, it ices up with frost on it(but it still runs). After putting in a carb kit, dist. cap, dist. rotor, and cleaning the gas tank this fall, it will run just fine while sitting and rev up to a fast speed. However to get it to start and run, I have to have the choke closed all the way. After it warms up, I can open the choke a little and it runs even better. I can run around and move bales in low gear all I want with the throttle wide open. Whenever I put it in second gear, it will not even pull its way up a slight incline without bogging down and killing the engine. Then I have to start it with the choke all the way closed and drive in low. It did that during warm as well as now during cold weather. The engine has a fair amount of blowby, but if it will move around in low gear all I want then I don't think that is the problem just moving up to second gear. The carb is open right now with no air filter setup on it. I am working on adding some type of air filter to it using rubber hose and plastic pipe. The intake manifold has fairly fresh oil residue around the end bolts at the front and back ends. I suspect there may be an intake manifold leak somewhere which may be the reason I have to have the choke closed most of the time but I'm not sure why oil would appear around those intake bolts and I'm not sure why that would affect power in any gear above low. This may be two different problems but I am wondering what everybody thinks is going on here. Other that what I listed here, it starts quickly and easily when fully choked.
