MV BELT PULLY
Bud W
01-07-2008 17:30:26
I want to add a belt pully to my 48 MV . Does the battery box have to be moved to install the drive unit? What would be the correct pully for a 48? Steel or paper and what diameter? I assume I just remove the delete plate and the drive will drop in place?
Thanks
Bud
agpilot
01-08-2008 16:14:17
 Re: MV BELT PULLY in reply to Bud W, 01-07-2008 17:30:26
Hello Bud W: Wasn't it about a month or 2 ago that there were a couple posts talking about getting the right clearance for the gears to mesh when putting a belt drive unit on? Try using the search function. I'll look also. ag
ejr-IA
01-08-2008 09:31:56
The 11" paper would be standard.
Andrew Z
01-07-2008 17:36:03
Yes just remove the delete plate and instal. for 48 paper would be the correct one. The battery box should not have to removed but it may be esier with it off.
Andrew
RustyFarmall
01-07-2008 18:47:07
 Re: MV BELT PULLY in reply to Andrew Z, 01-07-2008 17:36:03
You will want to remove the battery box, but when done, the box can go back on.
