1066 factory engine horsepower
Brad M
01-13-2008 12:28:55
Anyone know the factory engine horsepower for a 1066?
Hugh MacKay
01-13-2008 20:12:58
 Re: 1066 factory engine horsepower in reply to Brad M, 01-13-2008 12:28:55
Brad: I don't think many of these folks know what engine flywheel hp is. Most of them are coming back quoting you drawbar and PTO horsepower. I don't think combine figures will be accurate. I knew this figure back when I bought a new 1066 in 1975. This is not right sccurate but I think you'll find 1066 engine flywheel is 12% to 15% higher than PTO horsepower.
I don't know as this matters a whole hell of a lot, most 1066 I've come across and I'm talking back when they were new, and as they came from the factory. My 1066 cranked 158 hp from the factory, and I've heard of at least two dozen others that came in between 150 and 160 on PTO.
I owned 16 new or close to new Farmalls in my lifetime. Of the 16 only one did not exceed both manufacturers ratings or the Nebraska tests, and most of them went 8% to 15% over. The one that didn't measure up was a Farmall 504 gasser.
El Toro
01-14-2008 05:23:57
 Re: 1066 factory engine horsepower in reply to Hugh MacKay, 01-13-2008 20:12:58
The Federal government used those 504's for mowing off their firing ranges. They were pulling big batwing rotary mowers and they had a
box type cab made from armor plate to protect the driver in case they hit a dud. Heard they had a lot of problems with the engines and since they didn't have sleeves they sold them at their property disposal auction. Then they bought big Ford diesels and back then they used the low bid contract. Hal
sammy the RED
01-13-2008 19:25:26
 Re: 1066 factory engine horsepower in reply to CityBoy-McCoy, 01-13-2008 12:28:55
macco said: (quoted from post at 06:26:45 01/14/08) I was told once, first 3 didgets was drawbar HP. Last didget was # of cylinders. Anybody know if this is so?
Example-1066- 106 HP, 6 cylinder
1468- 146 HP, 8 cylinder
806 - 80HP, 6 cylinder
Nope, not true. :D
randy hall
01-13-2008 19:06:39
brad. if you want to know flywheel horsepower get the specs from a combine that uses the dt414. they always quoated flywheel horsepower for combines.
macco
01-13-2008 16:26:45
Example-1066- 106 HP, 6 cylinder 1468- 146 HP, 8 cylinder 806 - 80HP, 6 cylinder
Tyler Fortney
01-13-2008 14:53:51
my 1971 1066 cranks out 116 horsepower But mine is an early 1066 yours could be a later one that cranks out 125 Horsepower
fred the swed
01-13-2008 14:25:42
1086 where set at 148hp and they both had the DT-414. Sorry but I donīt know the figure for the 1066.
LenND
01-13-2008 14:05:58
According to one book I have a 1971 1066 was rated at 125.68 belt power and 108.73 drawbar horsepower. But I think in 1973 or so they upped that horsepower quite a bit.
w gatewood
01-13-2008 12:39:39
the early ones were 2400 rpm and 116 hp and the later ones were 2600 rpm's and 125 hp
Brad M
01-13-2008 13:01:15
 Re: 1066 factory engine horsepower in reply to w gatewood, 01-13-2008 12:39:39
I think that's the horsepower at the pto . I was wanting to know the actual engine horsepower.
Thanks, Brad
