H PTO
Al in Mn
01-23-2008 17:16:17
What causes the PTO on an H to jump out of gear and what do you have to do to fix it?
Ole/Mn
01-23-2008 17:45:38
 Re: H PTO in reply to Al in Mn, 01-23-2008 17:16:17
Usually it's the splines on on the shaft. Remove the PTO assembly from the rear housing and check the splines in the long shaft. sometimes you can clean them up with a file if the PTO has been run under heavy load when not fully engaged. If that won't do it, used parts are not hard to find.
