F-12 mag
52 G
01-29-2008 07:11:29
Got the mag off an f-12 and it will fire good turning backwards, but fires very little turning in right direction. Facing the mag lug end turning counter clock wise fires good, but clock wise very little fire. What might be wrong, thanks Ken.
Andy Motteberg
01-29-2008 18:50:26
 Re: F-12 mag in reply to 52 G, 01-29-2008 07:11:29
It should only fire in one direction, it will not fire turning backwards. Are you sure you are not confused with the right and wrong direction to turn it? Does it have GOOD impulse? ("snap"). Make sure the impulse coupler spring is put in correctly and that the magneto coupler switch is on.
Fawteen
01-29-2008 12:32:16
Sounds like the impulse coupler isn't working. Can ya hear it click as you're turning the mag?
52G
01-29-2008 18:20:08
 Re: F-12 mag in reply to Fawteen, 01-29-2008 12:32:16
Yes the impulse coupler is working, and it fires a little, but you can turn backwards with your hand and fires real good, don't know what to do, thanks for any more info, Ken.
gene bender
01-29-2008 07:40:53
Its not supposed to fire turning backwards.
