Farmall 460 Diesel
1950 GM
02-11-2008 13:11:34
Was needing to find out if a 460 farmall came through from the factory with suitcase weights and bracket
Hayshaker
02-13-2008 05:30:16
 Re: Farmall 460 Diesel in reply to 1950 GM, 02-11-2008 13:11:34
All the Farmalls I hauled out of Farmall Works in Rock Island had no weights on them. If the customer ordered weights, they were usually shipped with the tractor. It was then up to the dealer to install the weights at the dealership. Its a lot easier to adjust the rear wheel width spacing before the weights are installed.
Brooks McCormick
02-11-2008 18:31:32
Suitcase weights were not available until the 06 series.
Armand Tatro
02-11-2008 15:10:38
Frogot to mention you should be able to bolt the suitcase bracket to the front of your 460 if you need to. Armand
Armand Tatro
02-11-2008 14:57:53
It is my understanding that suitcase weights and bracket didn' come out until 706/806 tractors. The 460/560 had slab weights for the front end if needed as an option. Armand
RustyFarmall
02-11-2008 13:33:34
No. Wheel weights, suitcase weights, etc were all optional.
