setting valve tappets correctly
tooltime
02-17-2008 11:48:11
ih 340 gas utility tractor. whats a good procedure for setting valve tappets. the firing order is 1342. thanks,Jim
Janicholson
02-17-2008 12:46:12
 Re: setting valve tappets correctly in reply to tooltime, 02-17-2008 11:48:11
Work on each cylinder independently.
As the exhaust valve just begins to start opening adjust the intake. As the intake just closes adjust the exhaust. Turn it with the plugs out, crank is best, but bumping the starter is OK. They are front to back
#1 EX INT---#2 INT EX---#3 EX INT---#4 INT EX
JimN
hillbillyOH
02-17-2008 16:49:36
 Re: setting valve tappets correctly in reply to Janicholson, 02-17-2008 12:46:12
I used a pipe wrench on the PTO shaft when I set the tappets on my Allis C. As long as you have the plugs out, you can make some pretty careful adjustments...
Just be sure to take the wrench off or disengage the PTO before trying to start her again. :)
tooltime
02-17-2008 14:39:44
thanks, ill give it it a try. i adjusted the tappets once, but i just made sure there was no pressure on each rod , by turning motor with hand crank little by little. i started at front, worked back, butagain im new to tractor mechanics and sure have lots to learn. thanks, Jim
Bob
02-17-2008 12:09:46
 Cut this link, and paste into your browser: in reply to tooltime, 02-17-2008 11:48:11
Link
