Henderson Loader for an A
Brad in TX
02-21-2008 13:44:10
I"m trying to get this moved and was trying to find out the approximate weight and dimensions of a Henderson loader for an A.
JT
02-21-2008 13:49:56
 Re: Henderson Loader for an A in reply to Brad in TX, 02-21-2008 13:44:10
I have one on a B, it probably weights 2-300 pounds, don't seem to be real heavy. probably 8 foot long, 3-3-1/2 foot wide. I can measure mine if you want me to.
Jim
tinyy
02-21-2008 18:28:54
 Re: Henderson Loader for an A in reply to JT, 02-21-2008 13:49:56
Can you post a picture or send me one I would like to see it. tomntonya at charter dot net
JT
02-22-2008 11:35:14
 Re: Henderson Loader for an A in reply to tinyy, 02-21-2008 18:28:54
Check your email, I sent you some pictures of mine, if you want any other pics, let me know. I just put mine on a few months back, so I have not used it yet, but I can see where it is going to be as handy as a pocket on a shirt. Plus it adds some weight to front of tractor, they tend to be a little light in the front end.
Jim
gene bender
02-22-2008 02:48:08
Would you like to buy one? They are handy as all as im always using it for something even when not pushing snow.
Brad in TX
02-21-2008 14:01:58
Thanks JT. That should be close enough. I figured it didn't weigh too much since the front ends on these aren't all that strong. Does it steer alot harder with the loader on it?
JT
02-21-2008 14:36:47
 Re: Henderson Loader for an A in reply to Brad in TX, 02-21-2008 14:01:58
Steers a little harder, I just got it about 3-4 months ago, so have not had time to play with it really, I was moving some snow with it a month ago, and with a bucket of wet snow, it did steer a little more difficult. A B also has a narrow front end, your A should be a wide front, so it will steer easier with the wide front over the narrow front, I would assume.
Jim
gene bender
02-21-2008 15:00:51
 Re: Henderson Loader for an A in reply to JT, 02-21-2008 14:36:47
Are you guys using the CHAR-LYNN pump for your loaders as thats what i have on a loader i built for the B. I made it like the new stuff so i pull two pins ans the two on the cycls and the boom is off. I made a blade to push snow works fine. I have another B with the same pump and have a three pt blade on the back just use a two-way cycl for the center link and only use one side to pic up as down pressure just causes a traction problem.
JT
02-21-2008 18:21:14
 Re: Henderson Loader for an A in reply to gene bender, 02-21-2008 15:00:51
Gene,
Mine uses a Char-Lynn pump. What is the possibility that you could take a picture of the snow bade and the rear blade and send to me. That really sounds interesting to me. If you can, please send to ihc103 at yahoo dot com.
Thansk
Jim
