560 Brakes
A nut
03-02-2000 16:38:17
Does anyone have any secrets on 560 brakes that grab and hang up? I was thinking about having them machined down to move brake hub in closer so the balls wouldn't come out so far.any ideas?
RickB.
03-03-2000 17:22:22
 Re: 560 Brakes in reply to A nut, 03-02-2000 16:38:17
Creative machining can work well here. Stack NEW discs and the assembled actuator in the brake hub. Put a straightedge across & measure down to the friction disc surface in several places. Machine hub mount face to provide .025" clearance in measured dimension. This will limit rotation of the actuator, provide maximum leverage on it, and allow the return springs to work effectively. This works on most IH double disc brakes.
Les Repair
03-02-2000 17:26:52
Make sure the three springs on the actuater are good and snug. Put grease on the wear surfaces of the actuater and the housing. Try flipping the actuater over when you put it back in the housing.
TY
03-03-2000 09:26:33
 Re: Re: 560 Brakes in reply to Les Repair, 03-02-2000 17:26:52
my brakes used to lock up all the time.all i did was tear the guts out of it and gave all the parts a good cleaning with brake cleaner-they needed it!
they haven't locked up since and that was over 7 months ago....hope this helps...Ty
