Farmall M Belt Pulley Shims
Bud W
02-28-2008 08:48:04
I resealed my Belt Pulley Drive but one of the shims ( part munber 49251D ) was damaged during disassembly and I have a leak through the shims. A couple of questions:
I don't have a micrometer so can anyone tell me the thickness of the two lighter shims ( # 49251 and 49252 )? The 49252's are available new but not the thicker 49251.
Also should I apply a film of liquid gasket between the shims? I can't imagine these old shims will ever seal with only metal to metal contact.
Thanks
Janicholson
02-28-2008 13:25:32
 Re: Farmall M Belt Pulley Shims in reply to Bud W, 02-28-2008 08:48:04
Spray both sides of the bent shim with copper coat, let it dry to near completely dry (just barely tacky) and reassemble. No Idea of the thickness. JimN
SuperA-Tx
02-28-2008 10:18:05
Cant tell you the thickness of the shims but mine had four of the same size on the Super A. When I put it together I smeared greese all over both sides. Hasnt leaked yet.
