H carburetor
Bob And
03-07-2008 20:09:37
Would someone be so kind to give me the float level setting for a '48 H Farmall carburetor? It's a single float. Also please state where you take the measurement. Thanks much.
Nebraska Kirk
03-08-2008 07:10:50
 Re: H carburetor in reply to Bob And, 03-07-2008 20:09:37
With float in raised position, it should measure 1 27/32 inch from bottom of float to gasket surface of upper body, with no gasket, and make sure you have the needle and seat intalled.
Dave_Id
03-08-2008 06:35:53
Tip carb upside down, and let it rest on the needle valve.. Set the float so it appears parallel with the base of the carb, and this should be close enough.
Bob And
03-08-2008 10:01:19
 Re: H carburetor in reply to Dave_Id, 03-08-2008 06:35:53
Thanks so much guys. Hated to buy the manual just to get this setting. Great Help. Hope Spring comes pretty quick. I'm getting tired of winter!!
RustyFarmall
03-08-2008 13:28:25
 Re: H carburetor in reply to Bob And, 03-08-2008 10:01:19
That info used to be included in with just about any carb kit you could buy. In fact, the diagram that I emailed to you was scanned from an old set of instructions that came in a NAPA kit.
