Need Farmall A Steering Sector
BobM
03-09-2008 06:54:53
Looking for steering sector for Farmall A.
Andrew Z
03-09-2008 12:33:37
 Re: Need Farmall A Steering Sector in reply to BobM, 03-09-2008 06:54:53
Ill count the teeth and see what i have.
Andrew
Hugh MacKay
03-09-2008 12:10:15
Bob: A major change in that steering system, occured around serial number 310300. The tyrods changed, steering control arm changed as did most of the steering box internal workings. I haven't seen all of this, however I suspect the boxes are the same, but if you change one moving part from steering wheel to the front spindle, you must change it all. I would check that in a parts book before ordering.
I've never been personally involved with any of the tractors before serial 310300, but I do know a couple of guys that made a lot of exchanges at the salvage yards before they had the right parts.
tn terry t
03-09-2008 09:32:26
 Re: Need Farmall A Steering Sector in reply to Re: 460 is a knocking..., 03-09-2008 06:54:53
Andrew Z said: (quoted from post at 04:57:07 03/10/08) Bob,
I have one off a 100 should be the same gear i can send pics if your interested. my Email is open
Thanks
Andrew
Andrew i have a sector gear out of an A in my 63 140 BUT the teeth count where different so i had to use the steering shaft out of the A slso the 140 now steers harder than it did because of the different ratio but its not that much so you will need to count the teeth
Andrew Z
03-09-2008 08:57:07
Bob,
Thanks
Andrew
