Throttle lever vibrates to low idle?
7lazy77
03-30-2008 14:04:22
When I throttle the engine up to high with the lever, the throttle slowly vibrates back to 600 rpm's. The tractor has an accelerator pedal so I usually just use that to keep my rpm's up, but it is a pain & probably hard on the tractor to keep increasing/decreasing the engine speed. Is there something I can do or a nut to tighten up to keep my throttle lever from backing off when I increase the engine speed? Thanks for the help.
JT
03-30-2008 14:21:07
 Re: Throttle lever vibrates to low idle? in reply to 7lazy77, 03-30-2008 14:04:22
What model would you be referring to? Most have a nut to tighten or a friction disc to replace.
Jim
7lazy77
03-30-2008 14:38:02
 Re: Throttle lever vibrates to low idle? in reply to JT, 03-30-2008 14:21:07
Sorry about that...It is an IH 784
