Farmall H starter
160dan
04-06-2008 09:47:56
Anyone ever take apart and replace with new gets the inside of a starter?
Mine stopped working. Turns out the bolt where switch connected spun a bit, broke connection inside. I tried to re-sodar it, looked ok, cleaned the armature and brushes looked ok too but a spark at the bolt and no turning. Must have shorted somewhere on the shell or something inside is just junk.
Note have any luck looking for those parts, amature/windings etc...just brushes on-line. I bought a used one that works but would like to rebuild/keep as spare or maybe sell...advise? Thanks, Dan
magman
04-06-2008 15:43:59
 Re: Farmall H starter in reply to 160dan, 04-06-2008 09:47:56
I have done what you said many times before and what happens is the part you soldered what does it have 2 flat peices of brass or copper? Well the way you have it when you put it together the bolt that goes through is probly hitting on one of those ribbons Fix that and try again. JON
160dan
04-07-2008 08:05:19
 Re: Farmall H starter in reply to magman, 04-06-2008 15:43:59
Nutz! didn't work! I tried it but just sparked again and I made sure no part of the bolt was sodared or touching walls or windings. Oh well, off to the electric motor shop I guess.
gene bender
04-06-2008 10:20:58
You probably didnt get a good job when you soldered that connection as not an easy chore even shops have a trick when doing that connection. You could have had anew one for 115 with 1yr warranty. Usually cleaning the slots and turning the commutator with new bushings and brushes will work if then the Bendix is ok.
Farmer Bob
04-06-2008 09:50:41
Although it can be done, probably best to take the old starter to a reputable Starter/Generator or Auto electric shop and have them rebuild the starter. You'll have a good spare when you are done.
