Farmall F-20
Andy Motteberg
04-06-2008 18:01:05
Does a Farmall F-20 IH Manifold and a F-20 Heisler manifold have the same size exhaust pipe? I need to know so I can get a muffler, I don't have the tractor here right now. Thanks.
the Unforgiven
04-07-2008 06:04:27
 Re: Farmall F-20 in reply to Andy Motteberg, 04-06-2008 18:01:05
OK Andy, here's what I've got. Original IH is 2-3/4 OD of the pipe, the two aftermarkets I have are just slightly less than 2-1/2 OD. Your results may vary.
F-Dean
04-06-2008 18:16:10
Why do you want to put a muffler on a F-20? They sound beautiful with a straight pipe!
Andy Motteberg
04-06-2008 18:18:04
 Re: Farmall F-20 in reply to F-Dean, 04-06-2008 18:16:10
Mine has a very long straight pipe on it now, but I think I like a muffler better.
Thanks.
ejr-IA
04-06-2008 19:50:16
 Re: Farmall F-20 in reply to Andy Motteberg, 04-06-2008 18:18:04
Its larger than a m's I think 2 3/4 id
Andy Motteberg
04-07-2008 20:55:47
 Re: Farmall F-20 in reply to ejr-IA, 04-06-2008 19:50:16
Thanks.
Andy.
the Unforgiven
04-06-2008 18:05:30
I think the Heisler pipe is the same size as an H or M, and the IH gas and kero manifolds with the three-bolt cast pipe used a little larger muffler.
Andy Motteberg
04-06-2008 18:16:52
 Re: Farmall F-20 in reply to the Unforgiven, 04-06-2008 18:05:30
Thanks for the fast reply, I was at L&M Fleet to get a muffler and the Stanley muffler catalog said that the Farmall F-20 and F-30 with Gas manifold use the IH-16 muffler. Do you know if "Gas Manifold" would be the Heisler manifold? If you don't know, I guess I'll just have to wait and measure the tractor when I get it picked up.
Thanks,
Andy.
the Unforgiven
04-06-2008 18:35:19
 Re: Farmall F-20 in reply to Andy Motteberg, 04-06-2008 18:16:52
The IH gas and Kero manifolds had a cast iron pipe with a flange with three bolts to fasten it to the manifold, and most if not all the aftermarket manifolds I have seen used a little smaller threaded steel pipe. If you have a Heisler or TSC manifold for sure I bet it uses the same size as an M. I have to go out and shut my shop doors yet tonight, I will measure a couple of them for you. Your safe bet would be to wait and measure yours to make sure.
Andy Motteberg
04-07-2008 20:55:28
 Re: Farmall F-20 in reply to the Unforgiven, 04-06-2008 18:35:19
Thank you.
Andy.
