farmall H radiator
Booth2563
04-09-2008 12:20:20
I need to know how them springs and washers go on on the bottom of my radiator and what order they go in.I forgot how they was when I took it off about 3 months ago.
Thanks David
Michael Soldan
04-09-2008 13:51:04
 Re: farmall H radiator in reply to Booth2563, 04-09-2008 12:20:20
The rad sits on pads on the bolster, the bolts stick through wher a spring , then nut, then cotter pin.
jal-SD
04-09-2008 18:07:00
 Re: farmall H radiator in reply to Michael Soldan, 04-09-2008 13:51:04
Be sure to lube the bolts with a good grade of waterproof grease, because you or someone else will REALLY THANK YOU FOR THAT at sometime in the future when the radiator has to be removed again. IMHO, taking the radiator off is the most miserable job there is in making repairs on an H. Those bolts are always rusty and you can only turn the wrench about 1/8 of a turn. (My $0.02 worth. jal-SD)
GeneMO
04-09-2008 18:13:07
 Re: farmall H radiator in reply to jal-SD, 04-09-2008 18:07:00
That's a big 10-4 there good buddy!!
Hate the radiator job.
Gene
