560 hyd problems
acdave
04-11-2008 19:52:40
i replaced several lines and hoses for the hyd system now i have it full of air how do i bleed it off any ideas thanks David
Hugh MacKay
04-12-2008 01:57:34
 Re: 560 hyd problems in reply to acdave, 04-11-2008 19:52:40
Dave: Hydraulic activity is the only clean or successful way to remove air from the system. Air must and will come to the surface within the reservior,which in the case of a 560 is the transmission. From there it will be vented to outside. For each valve you have air, with a cylinder connected operate the cylinder or cylinders full stroke about a dozen times. That should remove most of it, there rare cases that require more activity.
