H farmall oil leak
Booth2563
04-16-2008 17:44:35
Ok guys I found the oil leak on my H and it is comming out of a oil seal. When I lay down on the ground I can see two shafts one on bottom and one on top and the one on top has 3 bolts holding it together the oil is comming out of the top one. Is this going to be hard to fix? will I have to split the tractor to get to the seal. the oil is comming out the seal looking back toward the seat.
Thanks David
Wayne in MN
04-16-2008 20:34:39
 Re: H farmall oil leak in reply to Booth2563, 04-16-2008 17:44:35
Both transmission drive shaft & PTO drive seals are located behind the belly pump.
Remove the pump & the PTO seal is right there where the pump drive connector was located. Put the transmission in reverse & lock the brakes. Use a bar or pipe wrench to unscrew the drive lug, lefty-loosey.
Remove the 3 cap screws & the housing comes off with seal attached. Replace the seal & gasket, replace the 3 cap screws, screw the drive lug in, righty-tighty, & you are done. Some oil will leak thru the bearing while you are replacing the seal.
Transmission drive is similar but you must remove the drive shaft coupler to get at the seal. Tip: when the nuts are off the tapered bolt, hold the coupler drive with a pipe wrench & turn the tapered bolt to loosen. Don’t try to drive it out or damage will happen.
Nebraska kirk
04-16-2008 18:33:33
You don't have to split the tractor. You will have to drop the belly pump, if there is one. Then you will have to remove the input shaft coupling. The coupling held together with 4 bolts. The bolts have a tapered section on them and will have to be knocked loose with a hammer, loosen the nut until it is flush with the end of the bolt, then hit the nut with a hammer until it comes loose. Each bolt has two rubber washers & steel cups, make note of their positions and make sure they are put back the same way. 2 of the bolts have the nuts facing toward the rear of the tractor and there is not enough room to swing a hammer, what I have done to get those two loose is to rotate the shaft until the nut lines up with one of those three bolt heads and then take a pry bar and pry foward on the tapered bolt until it pops loose. Now remove the bolt that holds the yoke on the transmission shaft, the yoke will then slide off. Now remove the 3 small bolts and the seal retainer will come off. Just knock the old seal out and install a new one.
While you are at it, you may want to replace the seal on the lower shaft too.
