Farmall wiring diagrams - new link
Bob M
04-23-2008 12:03:25
For Jim N, John T, Farmer Bob, Andy Motteberg, Jossette, Mike CA, et al:
Due to the pending (end of April) shutdown Epson's photo sharing, site I copied all of the more frequently viewed Farmall wiring diagrams to a new album on Flickr.
A link to the new album is below.
Note - Since I posted these diagrams on Epson several years ago they've had over 300,000 views. Somebody must be looking at 'em(!)
..Bob M
Edmund T
04-30-2008 07:12:57
 Re: Farmall wiring diagrams - new link in reply to Bob M, 04-23-2008 12:03:25
The generator on my 504 died (arm that holds the brushes rusted away) and I want to convert to an alternator. The one wire delco seems to be the choice, but do I need the adapter and does this one wire just go to the battery, or, do I need to bypass the tractor voltage regulator? Any help appreciated.
Edmund T
04-30-2008 11:59:46
 Re: Farmall wiring diagrams - new link in reply to Edmund T, 04-30-2008 07:12:57
I talked with one company that sells the single post alternator and adapter for the alternator to replace the generator. He said the adapter would raise the alternator an inch and a half and there might not be clearance under the hood? Also, he recommended wiring the single post off the alternator to the Amp meter and from the other amp meter post to the same post on the solenoid that the battery attaches too (positive). Is this what you all recommend and does anyone have experience with this? Any help appreciated.
Bill Bowen
04-24-2008 12:56:34
Thanks for the diagram,I am rebuilding a Farmall H. I check out your photos which is your main love,tactors or trains.I like them both but its easier to get a tractor.Is there a website that I can go to ,to see updated photos. Thanks Bill
Bob M
04-24-2008 17:52:20
 Re: Farmall wiring diagrams - new link in reply to Bill Bowen, 04-24-2008 12:56:34
Bill - I prefer the old tractors myself. My wife is more the railfan - though she likes the old tractors too. Punch the link below for a few albums of our railroad shots.
Expect to be posting my photos 2008 tractor shows etc. on my Photobucket account: http://s101.photobucket.com/albums/m46/farmallbob/
jal-SD
04-24-2008 08:14:57
Thanks a bunch, Bob. We've even used the H w/mag diagram to wire an SC Case w/mag. The electrical system might think it on a Farmall, but the SC doesn't care. All lights, etc work just fine & the battery stays charged. (My $0.02 worth. jal-SD)
IH2444
04-24-2008 05:05:23
Thanks for sharing the wiring phots with everyone Bob. I know I have given the link to a few people who needed tham.
Bob M
04-24-2008 04:44:33
 Re: Farmall wiring diagrams - new link in reply to Steven f/AZ, 04-23-2008 12:03:25
John T said: (quoted from post at 21:41:12 04/23/08)
Hope we meet up again at another show
John T
Likewise John T... and to meet the lovely Mrs T again too!
...Bob M
FarmallDude
04-23-2008 21:30:31
Bob M, thank you SO MUCH for your diagrams, I don't know what I would have done without them.... You-R-Da-Man! Do you have a Diagram for a H / M 12 volt alternator conversion, with Magneto (Push-Pull Switch)?
When I start my 1941 H (With Magneto), I have to get off the tractor and touch the # 1 wire to the Hot Terminal of the Alternator, to excite....
Now, after I excite the alternator, its good to go and when I turn the tractor off, go back in a hour, start it up again, it will take off charging.... I believe it starts charging, cause I put a Small Pully on the 10-S1 alternator.
Thanx, Bob M!
Janicholson
04-24-2008 06:10:35
 Re: Farmall wiring diagrams - new link in reply to FarmallDude, 04-23-2008 21:30:31
I'll add to Bobs good solutions one that keeps it looking stock at the controls point of view.
From NAPA, buy a oil pressure switch with two terminals that is closed with pressure above 5PSI.
Wire this from starter switch battery terminal, to the oil sw, then from the other term to the #1 on alt. Thus when running it automatically gets exciting voltage, and when stopped, that sw stops the exciting volts. JimN
FarmallDude
04-24-2008 21:22:05
 Re: Farmall wiring diagrams - new link in reply to Janicholson, 04-24-2008 06:10:35
Jim N: Thank you very much, for the good info on the oil pressure switch. I WILL go to NAPA or Carquest and get me one. Both auto parts, are Real close.
Thanx, again Jim N
BTW, you're not related to Jack, are you!? ;-)
Bob M
04-24-2008 07:04:15
Jim/FarmallDude - That's a good one too and I've got a diagram for it...
Bob M
04-24-2008 05:45:38
FarmallDude - Thanks for your kind words!
Probably the simplest solution to your problem is to wire up a pushbutton switch to the alternator #1 terminal. Upon startup hit the button to “flash” the alternator so it will begin charging.
Another option is to replace the original push-pull ignition switch with a DPDT toggle switch. Use one pole to short the magneto in the “off” position, and the other pole to feed power to the alt #1 terminal in the “run” position.
I have diagrams for both. If you open up your email I'll send 'em along.
FarmallDude
04-24-2008 16:08:54
 Re: Farmall wiring diagrams - new link in reply to Bob M, 04-24-2008 05:45:38
Hi Mr. Bob M,
Please send the diagram for my H Magneto, with 12 Volt Alternator Conversion.... My e-mail is open Now.... Bob, I can just put # 2 wire to the Hot terminal, right?
Thanx, Mr.Bob M!
Oh, BTW, I live pretty close to you.... I"m near, Brockport. ;~)
Andy Motteberg
04-23-2008 19:34:54
Thanks for letting us know Bob!
Andy.
riverbend
04-23-2008 19:06:59
Thanks Bob
Greg
John T
04-23-2008 18:41:12
Thanks Bob, wow 300,000 views, I bet thats more then some naughty sites get lol
John T
Old Iron Larry
04-23-2008 15:35:06
Thanks Bob, I have most of your wiring diagrams printed and in my tractor repair box. I have used them on Case and AC also.
Peculiar Farmer
04-23-2008 14:31:28
Bet the other 299,999 were as grateful as I, thanks for sharing.
Janicholson
04-23-2008 14:04:10
Nice move, JimN
little john
04-23-2008 13:50:15
Thanks for sharing them all this time. I used one to rewire my "H" several years ago and it was the answer to a lot of questions. You have provided a great service.
Mike CA
04-23-2008 12:47:52
Bob,
I have some specific questions I"d like to ask you about possibilities for my wiring. Can you please e-mail me?
e-mail is open. Thanks.
ScottyHOMEy
04-23-2008 12:31:30
You're a true gentleman, Bob. It's hard to tell how many folks chasin' sparks around a tractor you've bailed out by sharin' your diagrams, experience, and good advice.
Thanks!
Tom Olson
04-23-2008 12:29:34
Many thanks! I"ll be using them again soon to get my SA charging system working.
Tom
RustyFarmall
04-23-2008 12:19:01
Thank you Bob. I've used those diagrams a few times myself.
Joe Kimbriel
04-23-2008 14:08:51
 Re: Farmall wiring diagrams - new link in reply to RustyFarmall, 04-23-2008 12:19:01
Thanks Bob, I have used them alot also.
