cnks had answered a couple of question. went on vacation and never got back to this post... so hhheeeee lllp please.have a 460 industrial gas. i think the clutch or ta is bad. put it in gear runs great, start pulling a hill.... yup slows down to a crawl!!!! tried to move some dirt, got a scoop, started spinning, tried backing out, put it ta low, sounded like a starter spinning with out ever hitting the flywheel! clutched it and put it back into high, sounded the same. turned the engine off and moved the lever back and forth a couple of times, started it again, and it was fine. (did not try to put it back in low again) moved a couple of more buckets again with the same result..... slows to a crawl when i hit a hill (does not make a diff what gear i am in) so.... is it the clutch, ta, or both? worth fixing or pass it down the road? i checked the price for parts. not too bad except for the ta. how bad of a fix is it? or rather splitting the tractor at home? did my little mf35. not that bad. the 460 is a lot bigger tractor! thanks for the help. cnks thanks again for all teh help so far!!!
