Oil for Farmall Model C
Blake and Bryan
04-24-2008 12:28:42
Hi Folks, we have just acquired a 1951 model C Farmall tractor and would like to know what oil to use in the engine crankcase? We would also like to know if the original was a 6 volt or 12 volt system We have manual on the way but it will take a week or so to arrive. Would appreciate any and all information you care to share with us. We are looking for full restoration.
Thanks
Blake
Andy Motteberg
04-24-2008 17:19:45
 Re: Oil for Farmall Model C in reply to Blake and Bryan Walston, 04-24-2008 12:28:42
I use Harvest King All Season oil in my Farmall H and it works great and gives very good oil pressure.
04-24-2008 19:19:04
 Re: Oil for Farmall Model C in reply to Andy Motteberg, 04-24-2008 17:19:45
Thanks Andy
04-24-2008 13:00:01
Thanks for the prompt reply. Will happily share any information we come up with in or restorations
Blake
Don L C
04-24-2008 12:46:27
Show...10 - 30w
Work...15w - 40 Shell Rotella T....this is what I use..... .your manual will say 30w.....but that was back in'51..... .Don SW Ohio
04-24-2008 13:07:12
 Re: Oil for Farmall Model C in reply to Don L C, 04-24-2008 12:46:27
Thanks for the information...was neat to find that the crankcase has no dipstick but two valves for high and low levels. We are not new to restorations but new to tractors so any help will be appreciated Blake
Keith-OR
04-24-2008 12:39:45
I run 30 weight in son's SC(10W30)..From factory it was 6V generator with positive ground. If someone has converted to an alternator then very possibly could be 12V negative ground..
Keith & Shawn(Special Olympic Gold)
04-24-2008 13:04:47
 Re: Oil for Farmall Model C in reply to Keith-OR, 04-24-2008 12:39:45
Thanks for ignition info now we know why the charging system does not work...starting to change it now.
Again thanks
Blake
arod
04-24-2008 12:33:13
I use 10W-30
04-24-2008 13:02:30
 Re: Oil for Farmall Model C in reply to arod, 04-24-2008 12:33:13
Thanks for your input. We do appreciate it.
Blake
