how tight on rod bolts ?
bob1965lonewolf
04-26-2008 14:26:58
put new bearing in today on a farmall m , how tight on the rod bolts ?
El Toro
04-26-2008 15:56:36
 Re: how tight on rod bolts ? in reply to bob1965lonewolf, 04-26-2008 14:26:58
My manual has 53 ft-lb for the rods. Hal
Don L C
04-26-2008 15:12:03
My manual says 55ft-lb.....
You need a manual....there is a lot more to it than tightening the bearings..... .Don
Binder Books, copies of IH manuals 503 684-2024
bob1965lonewolf
04-26-2008 16:21:35
 Re: how tight on rod bolts ? in reply to Don L C, 04-26-2008 15:12:03
well i checked them quickly before i took them apart and it seemed to be around 90 lbs - not stock crank - its a stroker crankshaft , don't know if the makes a difference ?
Bob
04-26-2008 20:24:19
 Re: how tight on rod bolts ? in reply to bob1965lonewolf, 04-26-2008 16:21:35
You CAN'T possible make a reliable determinatio of torque by messing with them before removing them.
