Update on M Fuel f
Bob
03-10-2000 03:37:11
Hey Red; It wasn't the distributor any way... This might be the reason that they sold the tractor in the first place !! I took the carburator apart for the 20th time and blow all the ports out agin. I did not get a throttle shaft bushing with the rebuild kit. that was the only thing that had not been replaced. acrrording to the service manual the 2 holes in it was to line up with the 2 on the carb. if they don't ,engine doesn't get air when reved up!!!Soooo the guy who installed it before had a hole not lined up.. part cost ($4.14) So the old story don't trust others work, check all you'r self.. I put bushing in correct way, and low and behold the beast roars.. Thanks agin for all the help everyone.
The Red
03-10-2000 03:57:50
 Re: Update on M Fuel f in reply to Bob, 03-10-2000 03:37:11
Are you talking about lining up the throttle plate on the throttle shaft which is adjustable? You lost me in your correction to the problem.
Bob
03-10-2000 04:11:35
 Re: Re: Update on M Fuel f in reply to The Red, 03-10-2000 03:57:50
No ,the hole in the top of the carb that the throtalshaft goes into.It holds the butterfly plate. Theres a bushing that goes in there. and on the throtal shaft there is a slot that lets air in when you open up the throtal.(economizer slot in shaft)
The Red
03-10-2000 04:25:57
 Re: Re: Re: Update on M Fuel f in reply to Bob, 03-10-2000 04:11:35
I am looking at the parts page on the M carb. I can't visualize the "slot" you are mentioning other than the slot where the throttle plate slides through. I do see an indentation on the shaft left of the throttle plate. Is that what you are referring to? It's been 9 years since I rebuilt an M carb. The H does not have that.
Bob
03-10-2000 05:08:42
 Re: Re: Re: Re: Update on M Fuel f in reply to The Red, 03-10-2000 04:25:57
If you have the it shop manual its on page30 at the bottom. fig.IH342 bottom of page it is refering to carb model E12or E13.
The Red
03-10-2000 05:48:11
 Re: Re: Re: Re: Re: Update on M Fuel f in reply to Bob, 03-10-2000 05:08:42
Well both of you have my curiosity up. I'll check it out when I get home today.
The Red. Ahhhhhhhhhhhhhh
03-10-2000 10:25:10
 Re: Re: Re: Re: Re: Re: Update on M Fuel f in reply to The Red, 03-10-2000 05:48:11
Now I see what you are talking about. Nope my Hs do not have that economizer slot.
Bob
03-10-2000 13:41:26
 Re: Re: Re: Re: Re: Re: Re: Update on M Fuel f in reply to The Red. Ahhhhhhhhhhhhhh, 03-10-2000 10:25:10
Good thing it doesn't Red. Has caused me a few headaches!!!! But now a good thing to know...
The Red
03-10-2000 13:50:37
 Re: Re: Re: Re: Re: Re: Re: Re: Update on M Fuel f in reply to Bob, 03-10-2000 13:41:26
I learn something on this board everyday. Thanks for the internet and the great Farmallers!
Bob
03-10-2000 15:14:02
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Update on M Fuel f in reply to The Red, 03-10-2000 13:50:37
DITTO !!!!!
Bob M
03-10-2000 04:56:08
Hey Red - Maybe only the later H/M carbs have the economizer slot? (I know both my SH and SM got 'em). Look in the I&T manual if you have one - I'm pretty sure it's described in one of the carb diagrams there.
And Bob's right - if that bushing gets installed with the hole lined up wrong, the motor won't run worth a *#&^+@! at certain load settings. (Been there...)
Bob
03-10-2000 05:04:51
 Re: Re: Re: Re: Re: Update on M Fuel f in reply to Bob M, 03-10-2000 04:56:08
Yea, it will drive you nuts!!!! after you have checked everything fuel, air, and juice and it still didn't run right it #@%#@*
