Belly mower replacement blades
bobcd
05-18-2008 14:54:46
I have searched and searched for a replacement blade for my 3 blade belly mower thats on my super A. The deck has no markings or numbers.
The only number is on the blade which is hard stamped on the blades #66102, the holes are off-set not in line and each blade takes (2) 7/16-20 UNF bolts.
No luck on the internet? I think it may be a IH mower or maybe a woods. It throws grass to the left. I was hoping that someone out their could tell me the Mfg. of the deck and where I might get blades?
Thanks in advance for any help.
Bob in PA
bobcd
05-18-2008 19:00:50
 Re: Belly mower replacement blades in reply to bobcd, 05-18-2008 14:54:46
Hello John & Hugh,
Thanks for your input.
I had trouble posting photos for you so I
did manage to get photos into the Parts &
Pieces Gallery as follows:
1. Farmall Super A-Belly Mower Unknown Make
2. Farmall Super A- Belly
3. Farmall Super A- Mower
4. Farmall Super A- Belly
This should help ID this Mower and Blade.
Thanks,
Bob
John M
05-19-2008 03:14:11
 Re: Belly mower replacement blades in reply to bobcd, 05-18-2008 19:00:50
I think its a cheap knock-off of a Woods or Danco mower, like maybe one of those you might would buy at say TSC. I have a Danco IH mower on my 154, it sits differentthan your, flat side to the front, and thats the way Ive seen most of them. I have seen one that was built like yours, but dont have a clue what it was, I just thought someone put it on backwards. I have one sourrce that may can help with that blade. Ill let you know this afternoon.
Hugh Mackay
05-19-2008 02:30:50
Bob: You got me stumped, I'm almost certain it's neither IH or Woods. In fact in my opinion, your mower is a 3 point hitch mower that someone has modified to work as a belly mower. I've seen that center roller on 3 point hitch mower, don't recall the make and model. It is travelling backwards compared to the 3 point hitch model I saw. It had V shape and roller behind and those gauge wheels on front.
I may be wrong on the modified assumption of your mower. The company manufacturing the 3 point hitch mower I saw, may well be selling it as a belly mower as well. I know Woods have a 3 point hitch model and the deck and some other parts are exactly the same as my belly mower. There is one about 3 miles from me.
John M
05-18-2008 16:08:51
third party image
Is this your blade? About 21" Long, 2 -3" wide?
Hugh Mackay
05-18-2008 15:48:08
Bob: A photo would help identify whether IH or Woods. When you say blades offset, I presume you mean center blade is back about 6" further than right and left. I think you'll find they are all that way, it's how they achive overlap without blades clashing. I think if you look straight back from front on the underside you'll see about 1/2" of overlap of blades on each side. That is why 3 - 20" blades give you 59" cut.
You might try looking in YT photo gallery, give you an idea of styling differences between IH and Woods. Type in each of A, SA, 100, 130 or 140 with belly mower. Then you may find them where mower is not mentioned in title. Better still go to Farmall gallery and type in "tractors with belly mowers" Wont matter the size, IH and Woods will each have their own styling.
I looked up blade numbers for my Woods mower, knew it wouldn't be the same as mine turns right. Three different blades but the highest number is 26559. Just wait, my manual also has blade part numbers for L-59 mowers, (left turning) 23825 for medium suction, and that is considered standard blade. Optional low suction 25977 or blade with welded fin 12091. Bear in mind my book is late 70s, now close to 30 years old. There could be updated part numbers, since that time, however I notice when I go for parts he doesn't spend time on cross reference.
