Farmall A
Abe Hatt
05-19-2008 15:03:54
Noticed my farmall A seems to have some smoke coming out of the oil filler tube is this normal?
Thanks in advance
tractorsam
05-19-2008 15:23:40
 Re: Farmall A in reply to Abe Hatt, 05-19-2008 15:03:54
The oil filler tube on the A does double duty as it is also the crankcase breather tube. A little smoke, especially when loaded, is normal and fine. However significant smoke generally indicates a worn engine as that smoke is compression gasses that have leaked past the pistons. If it still has good power and doesn't burn a lot of oil you've got nothing to worry about. tractorsam
