Serial Number plate
Bart
03-12-2000 03:11:08
I have a 1950 M with the ser. no. plate missing.I located the ser. no. on the block right front. My question is, are replacement plates available?Is it legal to replace them? Thanks for any input.
Bart
03-12-2000 13:37:18
 Re: Re: Serial Number plate in reply to Aaron, 03-12-2000 08:44:40
Aaron, Thanks for the info. Another site I didn't know about. Harold, I think that somewhere along the line,someone copied the ser. no. from the plate to the block. It starts with FBKM etc. Maybe not but it is at least an identifying no. Thanks again. It's going to take me years to get these two M's going at the rate I'm going.
Harold H
03-12-2000 06:05:49
 Re: Serial Number plate in reply to Bart, 03-12-2000 03:11:08
You can do whatever you want as far as I know since the tractor is not titled, however, the engine serial number is not normally the same as the tractor serial number on your 50 M. It will be fairly close. Replacement plates are available from several advertisers.
Harold H
