IH 350 Utility
Ben Spedowski
03-25-2000 18:35:57
This winter i had a small problem. My anti-freeze failed and it froze. I think i caught it in time and got it thawed out and replaced. But while checking everything out for water I tightened the valves up by accident not knowing what I was doing. I know how stupid. I am very good with my hands and was wondering how to adjust them back to how they should be. Can you help me please?
The Red
03-26-2000 06:42:37
 Re: IH 350 Utility in reply to Ben Spedowski, 03-25-2000 18:35:57
Ben this should get you into the ballpark since that engine is just a beefed up H, Super H, 300. Get the number one piston up on compression and set the valve clearance gaps at .018 cold. Then crank it until you are TDC on whatever cylinder is next on the firing order. Firing order is on the block on the spark plug side. The H firing order is 1 3 4 2. I bet the C-175 on that 350U is the same. I would check them all 3 times to make sure. Report back!
